It probably has an air leak somewhere.. You might want to check between the engine and manifold, if ya don't groove the bolt holes out some they won't line up very well.. Make sure your bolts are tight.. Take the carb off and run a file on the face of it to make sure it isn't tweaked.. People will over tighten the bolts and bend the tabs out so the carb leaks at the middle.. Run a file over everything and make sure it's alll one level surface, good gaskets, bolts tight, maybe some silicone...
The idle speed screw is just the big long one that the throttle plate on the carb crashes into.. screw it out it should idle down.. If it's out and idling high it's probably an air leak..
AND!!!!
look at the throttle butterfly in the carb.. Take the carb rite off and look and watch the thing open and close.. people will take em out then put them in and get them out of whack, turned a little, or pushed over one way or something (on the throttle shaft) and the butterfly won't close the hole completely off because it can't turn all the way back to flush and nice perfect fit in the hole like it belongs and that will make them do it too..
A leak around the butterfly in the bore of the carb..
