if you have the room on your bike? i have seen two different style mufflers that are very quiet. nelson round muffler on a super bronc and the flat spark arrestor muffler on a super bronc. i believe markG was telling me this summer he could notes the difference in power from flat style spark arrestor to a standard thread on unversal thread on muffler. so there could be some loss power when getting into the quiet mufflers,but not all.
here is something i have done in the pass if a person does not have the room for a muffler,but still wants his bike to be little quiter then straight pipe.
took some washers and split them up into a curly Q)))) use a bolt for my jeg.......:thumbsup: you can tig it together or wire feed it together.
place it into your pipe
drill couple holes in your pipe where you want it and weld it in.
grind the weld down and your finish.
you can see on this bike there is no real good place for a muffler and on this bike it would probably not look good with a big muffler hanging on it..:doah:
i find that the thick over size washers work the best to make a header flange. just lightly grind off the plating before welding.
finish bike the pipe was put on.
