really ya cant do that ?:shrug: ? not to be a smart ass but i have seen lots of drives like that and they seem to work just fine . my craptor uses something like that and its been forever and the belt still going .... well i cant say strong but then pulling some of the stuff i have made that thing pull ya just shouldnt do with a riding mower:doah:....
my moms small tiller had about the same drive as whats shown and motor . that thing went throw hell a few times . good old hard clay gumbo soil . like the hard hard clay , as a brick yard was built near by for the clay that was there .
made oh almost 10 years hard use before the factory belt blew . but not before it tore the bearings wright out of the chain case . and i got a new lower in there :grind::hammer::censure::grind:
Suppose it would be more understandable if it were known that I am somewhat of a purist when it comes to mechanical power transmission. Certainly you are right about seeing the 'back idler' on various drives at one time or another. You will never see it on an application other than 'non critical'. Tillers and minibikes are not 100% duty cycle designs but are adequate....for a while.
You can stop reading now or, if so inclined, read on about why the 'back bending belt breaker' was used and why far better alternatives are open but more expensive.
To prevent substantial added manufacturing cost [to an already outrageously priced item] a completely acceptable device to adjust belt tension was dropped in favor of a far cheaper one [the absolute cheapest].
The tensioner could have bee placed inside and pushing outward against the belt except that the belt guard would have to be bigger to accommodate.
A sheave, that has one side adjustable by threads, could have been used [an 'off the shelf' item]. The two sides of the driven sheave would be brought closer together or further apart to effect correct belt tension.
The 'jackshaft' would be designed to move fore and aft to provide belt tension adjustment.
A 'timing' belt drive [with belt sprockets] could have been used and would have totally eliminated the need for adjustment as 'fixed' centers are used in such a design and no adjustment is needed or desired. One of the Gates HTD belts X 3/4 width is what I would be looking at to use if it were to be a device that was to be bullet proof and have reasonable longevity.
The drive offered is very close to junk if reliability is a factor. Don't ride that thing any further than you are willing to push it back would be my motto if I owned one.
