White stripe 26lb springs are good to .325" lift
308x1.1=338.8"
Again I can't say it enough
Do the math
And unless you checked crankshaft end play with a dial indicator your far from perfect
Edit: I thought you have some champion rockers also this will fix the problem also
.308x1=.308" just under coil bind
Sent from my iPhone using Mores code
308x1.1=338.8"
Do the math
