Kinda hard to tell you the right stuff. Everybody's setup is a bit different. Altitude, weight etc.
You didn't say anything about a header, adding a breather is going to not make much of a difference. Anyway...The 140 tube from what I hear will increase the low end torque. High end it does very little. Choked to run right could be dirty filter or probably dirty fuel clogging the carb. If your plug is white when you pull it, it is too lean. Best way I know to get it setup is to buy a set of micro drill bits and drill your jets. Go up one size at a time, run it and check your plug. Time consuming eh? But if you guess at it and overshoot the mark, it will run worse than when you started. I learned that myself:doah: When you get it right you can buy the right size jet for your set up. The mini drills will have a size on them. CTjimi has an outstanding thread below found by using the search. After you clean the carb, buy a couple of those clear filters that OldMiniBikes sells, they are the cat's a$$ and will protect all your hard work.
http://www.oldminibikes.com/forum/honda-clone-predator-engines/42480-diy-re-jetting-6-5-a.html
