baja warrior, predator 212 hemi, tav2 clone.
bike is a trail bike so i won't be making speed runs. i've already hit 40mph and that's fine. planning on leaving the govenor in tact. i want to have an open exhaust and a high flow air filter. i know i will at least need to jet my carb, but should i look into getting a bigger carb? i've noticed the mikuni 22mm and the BSP/Clone RuiXing Carburetor. i don't know much about either or if i need either. i don't want to get more carb than i can use. should i look into either of these carbs or just get a jet kit?
if i do what's basically a stage one upgrade, will i need to change anything else? springs or timing or anything?
all i've done so far is remove the filter from the stock exhaust box and put in an autolite racing plug.
