I usually fill a squirt ketchup or mustard bottle with some slightly diluted Rustoleum inside my frames, tape up the holes, roll it around for about 10 minutes then drain the Rustoleum. Not sure if it helps, but makes me feel better, but...open to ideas on how to clean heavy scale and rust out from inside a fork. You basically have an L shaped piece of 7/8" or 1" tubing sealed at one end ( crimped at the axle end) with opening on the top ( near where throttle or brake would go.) The only flexible drill shaft extension I can find has a big chuck on the end that won't fit. Open to suggestions on how to get round wire brush in, around the bend and out or any other suggestions greatly appreciated.
