Clone height
Power Output 6.5 HP Gas Engine, EPA approved
Displacement / Stroke 196 cc; 4-stroke
Ignition Type Electronic ignition (T.C.I.)
Cooling System Forced air cooling
Idling Carburetor Adjust 1700 +/- 150 RPM
Valve clearance Cold engine – Intake: 0.15 +/- 0.02mm;
Exhaust: 0.20 +/- 0.02 mm
Maximum Power Output 4.8 KW @ 3600 RPM
Maximum Torque 11-N.M./2500-RPM
Distributor Timing Intake valve opening: BTDC 10 degrees;
Intake valve closing: ABDC 20 degrees
Bore and Stroke 68 x 54 mm
Spark Plug Type BP6ES, BPR6ES (NGK), or NHSPLD F6TC; 0.7~0.8 mm clearance
Gasoline Type Unleaded
Gasoline Tank Capacity 0.93 gallon (3.5 liters)
Drive Shaft Type Horizontal, ¾” straight, (3/16”) keyed shaft with ball bearings. Direction:
counterclockwise (facing shaft); Length: 2-1/4”; Central thread: 5/16”-24
Start Type Recoil
Speed 3600 RPM
Oil Capacity and Type 0.528 quart (0.5 liters); SAE 10W30 (in freezing weather use 5W30)
Engine Mounting Square pattern, 4 holes; 8.0-1.25 mm threads
Weight 33.8 lbs.
Overall Dimensions 12-3/4” L x 14” W x 10-1/4” H
Recommended Applications To drive: pump, sprayer, tiller, chipper, shredder, log splitter
Features Low oil shutdown, automatic
Longer engine life with bearing supported shaft
Meets EPA certification (2008)
Fuel shutoff valve
