If your chain is too tight, you'll have some drag on the clutch, If it's not the idle check the chain tension. If your idle is too high, back the idle screw out about 1/4 turn and see if it's ok. (The plastic phillips screw on the rear of the carb.) It kind of sounds like chain tension, because it moves when you pull the cord.
