I have a late model B&S 5hp motor that has been bored out, equipped with a larger carb, and overall tuned up. The problem I'm havin is that once I start the motor up its ok for the first few seconds but then the clutch/chain start to make a grinding noise. And it jolts forwards and usually dies.
The previous owner say's this is because the RPM's are higher than it was originally. Once I do get it to start up and drive it hauls some major a$$. But it begins to grind and bog down in the lower RPM turns.
What would your first guess the problem is?
New clutch needed? Lower the idle RPM's?
I'm kinda just getting started with small engines so I could use a little help.
Thanks a ton guys!
Thanks a ton guys!
