I have a Coleman CT200u. Most of the time nothing happens when i go to start it, every now and then it'll start for a few seconds then quickly die
Mods made:
-Governor removal
-Aluminum flywheel replacement
-Heavier springs installed
What i've done/tested:
-Cam shaft is aligned with crank
-Valve lash set at TDC, fixed from wrong lashing
-Spark plug replaced, fixed problem of difficulty pulling start cord
-Carb tested and replaced with duplicate from another bike
-Kill switch tested works fine
One thing i haven't tested was the timing of the flywheel since install, not sure if that could effect it.
Yes, i've lurked on this sub, checked out several similar posts, tried all that i could. The next step for me is i ordered a new ignition coil, will arrive tomorrow.
Any help is appreciated.
video of me trying to start it
https://photos.app.goo.gl/ELPrH1L25nXFKDKX8
Mods made:
-Governor removal
