Wanted to share finding in case others have this issue and look for some input.
With my driver off I can install the belt by opening up the driven slightly. Once back together, the driven pushes the belt to the top of the pulley when turned. This tightens the belt around driver bushing, almost to a point where it wont even roll. Bushing is free to spin without belt...
To rule out the belt (was using knock off comet belt) I robbed an original Comet 30 belt 203589 off another comet 30 I have on a different bike (that also measures 6 5/8" center to center and has a 6" driven).
Also tightens up on this comet.
Looking closely at the second comet 30, the driven pulley is farther apart when closed completely than the one I'm having trouble with. See pics.
Aside from shimming between the halves...I cant figure out how one might adjust this.
Or maybe just buy a bigger belt for the driven with the narrower close position?
What am I dealing with here...two different variations of comet 30 drivens? If so, this should be taken into consideration when buying comet belts.
These are both asymmetric drivens 6": Both appear to be comet 30? They are made slightly different (one has 3 white buttons, the other 6 black) I assumed them both to be comet 30s, one came off 1980 bike (tighter close white buttons) the other (wider close with black buttons off a 1990s bike).
Also, I can see rivets in one but not other from inside when both are closed (rivets are not holding driven open in second pic).
Thanks.
