Configuring Speedometer
joekd
That cant be right, a 26" wheel (common bike size) is 660 MM
60mm=2.3", how the hell can you put a speedo on a bike with a 2.3" wheel?
:censure: damnit!! :doah: lol
i just looked at it in detail for the 10th time and it says 'CENTIMETERS' not mm...
that should skew things a bit, eh?
ok so like i said earlier, with my 145/70-6 tire size on both wheels, i did the roll out method to measure the circumfirence. i just put some paste in the middle of the tire on one of the "knobs". and rolled forward with me sitting on it. I measured the two points on the ground and its ~44 INCH.
Now google convert
44 inch = 111.76 centimeters
which is much more appealing and within range.
One more question regarding this issue, do those numbers now look about right for my tire size?
vette66_00
Now google convert
I think it wants you tire height not roll distance.
Nah I think your right. Try it out. Put what you got and see what your speed is. Get somebody to run next to you in a car and then you can tell....or a GPS unit. You can adjust it to make it more accurate.
Riley
New Member
at walmart they sell good quality ones like that, but with more features like a clock and stuff... only 15 dolalrs
they give really easy instructions on how to calculate it
Ive been saving that one just for you tmak
Now google convert
yes 111.76 i correct, you could of just taken the tire size " 14 inch diameter " off the baja site. then X by 3.14 = ~44 then covert it to cm to get the 111.76, and all this was done from the sh**er while you are playing with paste in the cold.
Ok so after setting it to 111cm:
I weigh something like 190-200 no more no less.
The max speed recorded was 32 MPH on a 12t/70t setup with throttle limiter screw removed(6.5 HF). Tomorrow we will confirm with a GPS unit.
Does this top speed seem right? Not sure how others weighing 180 ish with stock motors hit 40-45 ??? 20lbs right makes that much difference?
Weight only has to do with rolling resistance 20 lbs is not going to be that much. 32mph on a governed motor seems kinda high. I got mine to 42 ungoverned with stock intake and a pos header and I weight 230lbs. Now Im sure it's higher with current mods.
Of course this is with a 6.5hp clone. If you have a stock motor 32 mph is about the fastest you will get it and it takes 4ever.
40mph is around 5500rpm on a DB with a 12/70 setup. that's doable with a billet rod and 18lb springs and otherwise stock 6.5.
confirm your speed with the GPS and then use one of the calculators in the sticky thread in the General section. if you know your gearing, tire size and speed you can figure out the rpm.
