Hey guys. Just picked up this little H30 side popper off eBay. It's got a keyed 5/8" shaft and a diaphragm carb on the long skinny intake.
I want to retrofit this engine to make it minibike-compatible. I know I need the cable-type throttle control at the very least, but ideally I would like to swap to a float-type carb and standard intake. Assuming there are standard (shorter, less restrictive) intakes that will bolt up. Will I need the taller governor arm since the standard intakes place the carb higher on the block? I know the tank will need relocated for the same reason.
Alternately, has anyone run the long skinny intake and diaphragm carb on a minibike application? How do they do? Will the cable-type throttle assembly still work with the existing setup? This engine is destined for my Sears Runabout/Bird Wren project where gobs of power is not a major concern. If the current carb/intake setup will work OK then I might just leave it for a while and upgrade a bit further down the road.
