Soooooo I can't find them again. I know for a fact I did because I almost bout a 60t and it was compatible. I've searched everywhere I thought I would've before... All I can bring is.... I can't say i'd be brave enough to try unless it was very meticulously done. I guess it would be that hard with the specs I added below. I'll keep looking.
From gopowersports dot com /sprocket-48-60-teeth-41-420-chain-dual-pattern/
It works
Posted by Jay on 13th Sep 2016
I searched all over for a 60 tooth sprocket to fit on the rear drive wheel of my Coleman CT200u minibike. I wanted to gear it down slower and with more torque. I could not find a 60 tooth sprocket that fit the hub on this minibike. I took a chance on this sprocket. The hub was bigger than the OEM 52 tooth sprocket and the bolt holes didn't line up. The hub on this sprocket was bigger so it would fit around the smaller hub on the wheel and this wasn't too big of a problem. The bolt holes had to be modified so I just drilled new ones in the new sprocket. That worked. This sprocket is a little slimmer than the OEM one and the teeth are more pointed but seems to be strong enough and is working with the 420 chain I had. I've only driven it around for ten minutes since installing it but it seems to work fine. Maybe it should have five stars. I gave it four simply because it wasn't quite right for me and I had to modify it but I kind of figured that would happen going into this purchase. The price was the lowest I could find for a 60 tooth sprocket, even though I had to pay an additional $11 or so for shipping. Delivery was only a few days. Overall, this purchase from this seller was a satisfying transaction.
I had never heard of them, but do you think a spindle hub might bolt up if there's one out there? Then the options are endless..
Specs for what's needed on rear:
Mounting Hole Distance (center to center, bolt hole circle): 3-3/16" (80 mm) (((3.1875)))
Center Hole Diameter: 1-9/16" (40 mm) (((1.5625)))
Overall Diameter: 8-3/16"
Mounting Hole Diameter: 5/16" (x4)
