Thinning the herd!
Custom built 1968 Taco 99 Trail Tamer full suspension minibike with race modified Briggs 5hp engine. One of a kind auto restoration quality restomod by OldMiniBikes member Havasu Dave, I bought it this last summer and rode it just 5 times. Loud n Proud this one. Pretty close to show bike. $600 come n get it. PayPal.
Note: I'm keeping the chain guard!
I really like the frame and would keep that, and will sell the engine separate, minus clutch and chain guard. $400+flat $50 for shipping.
Here's the rundown on the Briggs, built by OldMiniBikes member 125crazy:
New rings
New valves
New chrome piston (std)
New Mikuni 22mm
New dbl valve springs w/ locks and retainers
ARC rod (3.875) used w/ new bearing
ARC adj flywheel
bearing side cover (new bearing)
milled head
performance cam (265 actual lift at the valve)
billet intake
New coil w/ new Taylor 8mm plug wire
New air filter
New breather filter
walbro fuel pump
New fuel line
New fuel filter
New grade 8 head bolts
stainless side cover bolts, gas tank bolts, recoil cover bolts
copper head gasket
cool bore block w/ oil hole drilled on flywheel side for better oiling to the crank
New rings
New valves
New Mikuni 22mm
ARC adj flywheel
milled head
billet intake
New air filter
New breather filter
walbro fuel pump
New fuel line
New fuel filter
copper head gasket
