DB30 full throttle hesitation? Video
The govenor keeps your rpm's below 3600. At wide open throttle its common to feel the bike surging or cutting out if you hit the max rpm limit. If you put bigger tires on it the gear ratio would have changed. It's just a guess
After coming home and watching the video it looks normal. You have no load on it. Ride it and see if it still does it.
Cuda54
Do you have a dirty air filter? Or maybe a plugged fuel filter will do that to? Might be bad gas do you use regular gas. Is the high speed jet adjusted right?
Looks normal to me, give it some brake to put it under load, it will pull down engine, and back off the governor. Or, ride it, see how it goes and report back. :shrug:
