DB30 hydraulic brakes
Doc1976
Anyone have any good photos of how you routed the brake hose on the older DB30 mini bikes? First time using this setup and struggling to find the best way to run the hose, it seems short for the application. The kit I ordered was supposed to be designed for the bike, but it is not long enough for a good clean route to the rear wheel. thanks in advance
Doc
Run along top of frame and down to caliper , you will have to loosen the hose connection on the caliper to rotate it in proper direction , if done quickly you wont lose any fluid and wont have to bleed it .
Oh it is indeed hot. Longest lasting heat wave we've had over here. Killing my established bushes. I get about an hour in the garage with cooler on, before I surrender to the heat.
I'm here in se ky and am drownin in water. Its either rainin or i'm mowin grass. thats all I did all summer, hardly made any headway on any outside projects.
