So, I am in the middle of my Mountaineer build and am trying to figure out my drive system options. The bike has the Deepco driven pulley still on it, but of course, no driver. After a mild attempt to pull the bearing off the shaft, I am thinking I may leave the Deepco on there. It measures about 7 1/2" in diameter, and on the inside between the sheaves looks like 5/8".
A. Can I use a Comet 20 or 40 to drive it?
B. I want to use my big block briggs, which is 1" shaft - does that limit me to the 40 series?
C. Do I have to modify it to work?
D. I am guessing the center to center distance will be farther than the normal belts will allow, where can I find the proper belt?
Thank you!
Thank you!
