Hi all,
Im currently on deployment and have been ordering parts for my db motor. So far I have the following mods on my gx200 (160 head)...
26mm mikuni carb
.290 lift 246* duration cam from agk
RS s2 finned flywheel (+28 degrees)
RS adjustable pushrods
RS 1.3 roller rockers
26 lb springs
Honda flat top piston
Stock size billet rod
I'm also waiting on the machine work for my head to be completed by AGK. Will have the following...
Head milled .065
Port on intake and exhaust
28.5mm intake valve and seat
26mm exhaust (haven't quite decided on this yet)
3 angle valve job
I currently have the standard maxtorque clutch and was wondering if I need to upgrade? If so,what should I look at. What is the benefit of upgrading the clutch? I have little knowledge on clutches and would greatly appreciate some suggestions. Thanks much!
26mm mikuni carb
26 lb springs
Head milled .065
3 angle valve job
