Front Suspension--Plan B
Those of you with Gilsons know the biggest complaint is vibration in the front forks. The reason for this is the fork lower tube which fits into the fork upper (handlebar) is 0.790." The 1" upper tube is thick wall and is 0.835." Most people attempt to fix this by packing grease in the tube. Because I made the fork lower and couldn't find 0.790" tube (it is available from race car shops), I went with 0.625" thick wall tubing, sleeved the fork lower with 5/8" ID black pipe and welded it all together.
My idea was to use Delrin tubing to close the two diameters up, so I ordered 0.750 OD/0.625 ID tubing, thinking that a 1/16" gap (1/8" total) would work just fine. Nope. Gave me too much deflection in the fork lowers which would have destroyed a pristine fender in a heartbeat.
So on to Plan B. This time I ordered 0.875 OD/).625 ID Delrin. So what I've done is the reverse of the Arctic Cat upper fork tube nylon sleeve--the sleeve is on the lower tube. To make this work, I had to have the tubes machined and the best way to make sure the machined tubes fit, was to provide the machinist with a small section of 1" tube. You honestly don't want to know what it cost to have this machining work done :doah::doah::doah::doah::doah:.
The Delrin is a compression fit on the fork lower tubes and slides easily in the upper with no deflection. They are installed with grease just to make sure everything moves freely. I also had to make a slight adjustment to the springs to make sure the front axle was level because there is now zero wiggle room.
Here's the first iteration:
The machined new sleeve:
This photo shows the fit at 0.82" and where the original diameter was turned down.
Problem solved and should address the fork vibration issues completely.
