Dear OldMiniBikes members, I am currently working on fiberglass molds for thermo/vacuforming the fenders, chain guards, and cowlings needed for my Fox Campus restorations. One of the requirements is a series of .010" dia holes drilled into the molds to allow any trapped air to be drawn out. For those of you who have never seen .010" hole; it is approximately twice the diameter of a human hair. My first thought was to try a Dremel too at various speeds. Four broken bits in two minutes convinced me that that wasn't going to work. My second attempt was to use a pin vise turned only with my fingers. Using various turning speeds and pressures left me with a pile of twenty or more broken hss and carbide bits. Obviously that wasn't going to work either since most of the bits broke off flush with the surface of the mold and couldn't be extracted. After a week or two of sleepless nights I finally came up with a solution and it works beautifully. Since almost EVERYONE has a need to drill a .010 dia hole at one time or another; I thought I'd share my method with you. To give you an idea of what I'm working with here; pic#1 shows a .010" dia drill bit placed next to a penny. In order to end up with a .010" dia hole I started out by drilling a larger .035" dia hole. The .035" dia bit was stiff enough to drill through the fiberglass without snapping or breaking. Pic #2 shows my pin vise with the .035" bit installed and the smaller .010" dia bit to the left of it. Pic #3 shows the pin vise drilling the larger .035" dia hole. I drilled two holes side by side so that I would be able to compare the finished .010" hole with the original one that was .035" dia. See pic #4 After the hole is drilled; clear tape (like in pic #5) is placed over the good side of the hole that needs to have its diameter reduced. To be continued:
