Straight 30 weight, if you can find it. If not, conventional 10w30 works too.
Do not let it idle.
Use up and down rpm to seat the rings. Dont let it set too long at a steady rpm. Keep moving throttle. Keep it above 2500 rpm, to break in the cam, for the 1st hr.
I like to put a hot cycle on the engine, a good hr or so. Let it sit over night. Go back and check all bolts and nuts, and valve lash, then put another hot cycle on it.
I usally have the engine on the test stand for 4 or 5 days, looking for anything that comes loose, or leaks, or what ever.
If it's gonna break, I'd rather it break on the test stand and not a mile down the road with no cell signal.
I change oil the 1st, 2nd, and 3rd hr, looking for metal in the oil.
After break in, I use Mobil 1 10w30 full synthetic.
This is my way.
You can always jus throw it on go. And wait for parts to fall off. Your choice
