You might have to open up the diameter slightly on the 3 inside holes (metric to inch stuff) but I run this setup on a couple of bikes with no issues.. the rear end pictured is the back of My Terra Cat.. but its very close to the el burro rear end.. I also run this setup on one of my elburro's with no issues.. You will need to get an offset rear steel wheel for the front and back.. and also need to "flip" the wheel and mount it backward on rear axle due to the sprocket being welded to the axle assembly...
