Hey guys I am having a slight problem with my mini bike. The engine starts in 1-3 pulls with the choke up, but once the engine is warm and I put the choke down it dies. Also the idle screw seems to do nothing whether its screwed all the way in or out and the engine idles around 3600 rpm, clutch engages around 3500, but I'm going to adjust the springs and change engagement to around 3800-4100. also the fuel/air screw seems to have no effect on the idle. Sometimes when I put the choke down it stumbles then picks back up and is ride-able, but thats rare. I can ride the mini bike with the choke up with no problem it doesn't bog or sputter. I'm thinking maybe my pilot jet is too lean? My pilot jet is at a 30 and my main jet is a 190, but the engine is modified with flat top piston, arc rod, arc flywheel, 30 thou milled, 28/25mm valves, 26mm mikuni vm26 + few other goodies. Any advice or suggestions will be greatly appreciated. Threw in a few pictures, well because who doesn't like pictures? :thumbsup:
free screen capture software
