Well my engine started doing this last time I was home. I haven't been able to get into to see exactly what is going on but wanted to know if any of you have run into the same problem. Engine has less than 15 hours.
did you try disconnecting the oil sensor if it has one? just to see if that makes difference.
could also be carb/governor related? you said idles fine.....dies under load right?
Yes I did disconnect the low oil sensor but it didn't help.
And it idles perfectly, just slowly dies under load but as soon as I take the load off it will rev up and run just fine
