Here goes my first attempt at a mini bike build. I picked a ragged out frame in need of Lots of TLC. Knee Replacement surgery slowed me down but Yellow Hand urged me to get busy, so I did. Here are a few pics of what I've done so far. The aluminum rear wheel had a big hole in the rim so I replaced it with a new one from Northern Tool with hub and 60 tooth sprocket. This didn't fit the frame so I created a rear frame section made from 3 in. channel iron and some 1/4 in. plate. Everything welded and braced , the rear hoop is 1 in. square tubing
The seat mount is 1 in. square with a front hingepin mount, attached to a rear shock from a old Honda bike. Probably make some sort of solo seat with a lip on the rear to keep me from sliding off the rear. Had to have some spring for my bad back.
The handlebars are a work in progress sort of a Ape hanger look. Still have a few other ideas .
For power I have chosen a 6.5 hp clone from Harbor Freight with a clutch I picked up at Tractor Supply. More to come later wish me luck. Thanks for getting me going Yellow Hand.:thumbsup: View attachment 4918
