I found an easy way to cut the high spot off an ez spin cam. I chucked the cam in my metal lathe and used a dial indicator to see where the high spot was. Then I put the cutter on the bottom of the lobe and turned the lathe chuck back and forth by hand to shave off the spot .This about .010 high from the bottom of the exhaust lobe to about half way up the side. Then just clean it up and blend it in with a fine file, recheck with the dial indicator and you're done. For those that don't know, the ez-spin feature slightly opens the exaust valve on the compression stroke to make the engine easier for joe homeowner to pull start. This compression loss can only rob low end power and torque. Cutting it off the cam is better then grinding the valve shorter because you are losing lift . If you want to check your briggs to see if it has the ez-spin do this. Take the head off and turn the engine by hand if you see the exaust valve open slightly on the compression stroke it is an ez spin engine. I don't know how much power loss it causes but this is something to deal with if you do are going to mill the head and stuff to get more performance .
