You need to think about this, just a tad bit more,
ut: before you break out the power tools & start cutting away all halfast.
To build compression, both valves must be closed. If the valves are closed, what is the position of the camshaft & lobes? More importantly... Where are the tappets? Most likely sliding along the backside of the cam, or more commonly referred to as the base circle.
I believe that is where I would be looking for a strange little bump, instead of :grind: on the peak of the lobe or :hack: your valve shorter.
Anyone recall that old saying about, A little bit of knowledge...?
