Remove the spark plug ,pull the starter rope 10 to 20 times with the fuel shut off ,replace the spark plug with a new one (you can burn off the gas with a torch then wipe the plug clean with a rag if you really want to save the old one ) then start it up .Check the oil to make sure the level has not risen with gas and if it has ,change the oil before starting it up .
