The engine he is looking at for 135 has no governor.
Thanks Toys. I didn't realize it was the BSP bare bones. For the experts, (not me) here are the rest of the specs if (like me) you didn't bother to go over to OldMiniBikes, look under engines and figure out what he was talking about. LOL!
JT, the order form give you the opportunity to add a billet flywheel for a buck-o-five. That's what I'd do.
Select Your Flywheel
This engine comes without a flywheel. Add a billet steel or aluminum flywhel in the product options for safety when running higher RPMs. This flywheel is mandatory for BSP racing!
Max Stroke Crankshaft
Forged "Max Stroke" 2.130" +/-.002 Stoke Crankshaft with hardened journals
BSP-2 Cam
NEW BSP-2 Box Stock Cam pre-installed in engine
Ruxing Carb
Ruxing Carb with adjustable idle mixture screw No "chatter" carbs here
Piston Specs
Piston is .003" to .008" in the hole yielding a low 26.8cc to 27.2cc combustion chamber volume
High Flow Head Casting
