Hello all,
I've been having quite a bit of issues with my rear sprocket. The rim and sprocket are a one piece assembly, and cannot be seperated. The tire size is a 4.10x3.50x6. The sprocket doesnt appear to be "true" and wobbles when rotating. At higher speeds i believe it is causing the chain to be thrown, which in turn causes the chain to become lodged between the sprocket and the frame. Has anyone repaired one of these before to make them true again? is there a replacement wheel i can buy that will fit? I'll post measurements later in the week. I think the sprocket is for a 35 chain as the 41 im using is a bit wide. I am also going to build a secondary tensioner for the chain and see if that helps.
Photos and measurements will come soon, Thanks in advance!
