disclaimer:I dont suggest you do this I am only sharing my experience if you do this you do it at your own risk
I used to weld gas tanks all the time I would empty them then fill them with water from a hose and let it overflow for a few hours then drain it
the first thing I would do is shoot the flame down the filler neck and even after hours of running water through it it would still ignite (WHOOFF!) then it was ok to weld I would only do this with small tanks like the ones mounted to small engines
once again if you are dumb enough to do what I do you are doing it at your own risk
ut:
