For the record, years ago we would solder or weld tanks fairly often. Our trick was to empty the gas then dump in a quart or so of alcohol. Slosh that around for a bit, dump then rinse with water. Alcohol mixes with gas, water mixes with alcohol. When you are done just reverse to remove the water. Never had a problem.
