I have a 14cc gx160 head but for some reason the inlet valve will not come out of the head. Is this normal on them head? I have a gx200 head and all was fine with that one.
im thinking novanick63 means file the stem . if the valves move to a point then sticks you have a bur on the stem and its sticking in the guide . file it down and it should slide out :thumbsup:
Stock valves are easy to bend, so they sometimes mushroom or get a slight edge keeping to from coming out later on. With slight grinding on the tip of the valve like said it should slide right out.
