The late model H40 is actually the same as an H35, They did away with the HS I imagine to simplify production. So the intake and exhuast are flipped compared to an HS. so if you were going to use a cam for an HS you would need to swap around the intake and exhaust ports like an older HS, would it work, I dunno?? Few people have started similar projects with the side exhaust H blocks (so intake would come in from the side) but no ones ever shown a completed running one. I woudl think it would be doable, the late model cranks and even rods in the H engines actually got beefed up to the HS size (just smaller head/piston, but I think clearance is reduced a tad so a billet rod will not clear like it would in the older HS blocks.
