I decided to make this a post on its own.
Hard starting... when you change the air filter and or exhaust, the idle circuit does not create enough vacuum... the solution is to open the idle jet. Where is the idle jet? you ask?
its under the throttle set screw...
1 - Take out the throttle set screw
2 - there is a black plastic plug under it, pry that up.
It has a large hole in the side and a tiny hole in the end (that is the idle jet)
3 - Drill the idle jet to .024 (to start with)
If you play with the little black cube on the side of the carb...it pulls off.
you can get it to idle better, but to get it to start better, you need to drill the jet.
I have pictures at www.4racers.com/clone under the gallery.
Later,
Gundy
4racers.com
Later,
Gundy
4racers.com
