hard to find Tecumseh HS40 diaphragm 1968-1970 for slanted engines
Fresh off a 1970 Fox, we wont be needing it as the engine will be used in a standard application and would have came with a bowl carb. This is the actual HS40 one, with correct choke lever, throttle arm etc.. used on slanted Tecumseh engines pre 1971. Engine is running but I would rebuild the carb, throttle shaft feels good though :thumbsup:
This is for the carb only, $55 shipped, last pic shows the numbers of the engine its on (1970 longshaft HS40)
View attachment 74479 View attachment 74480 View attachment 74481
Also possibly available will be the hard to find bushing sidecover longshaft for T/C and some 2 speed clutches. If I have a spare standard length crank it will be available, if not it will have to get circumcised :laugh:
they the first three digits in the casting numbers for the carbs that the HS40's used were 356
Loren, haven't forgotten about the crankshaft, just haven't torn then engine down to inspect yet.
