Creia -- is correct, bolt and washer only to hold a clutch in place. We no longer put set screw holes in our clutches for the 3/4" crankshaft. You want the clutch to be able to float on the crankshaft so it can self align with the rear sprocket that NEVER runs true. The Max-Torque clutch is .070 shorter than the crankshaft just so there is some built-in float. When you hold a clutch in place you want the pressure of the bolt on the crankshaft NOT on the clutch. 95% of crankshaft on the 3/4" are drilled and tapped. If you have an old American made engine that isn't drilled, then do it yourself and put a 1/4"-20 hole in it. Foreign engines you will have a problem drilling since for some reason they heat treat their cranks and since nothing spins free on them why heat treat them? One of those mysteries in life that we will never know the answer to.
