So i pulled out the Boonie Bike jackshaft, and took it apart. Now i see why it seems like *no one* has a stock and working boonie bike 2 speed transmission!
Before disassembly:
More of the 2 gear side as it's being taken apart...
Removal of the 2 geared side of the shaft reveals the problem... that spring probably shouldn't be broken in half!
Also looking at the shaft itself, i'm pretty sure that's all wear you see here. I find it hard to believe it would be this conical shape from the factory!
I'm not even sure how this gear is supposed to work....
Bottom line... i'm pretty sure i'm never going to find these parts. What have others done? Do i just put a Torque Converter on the jack shaft and forget the original 2 manual gear transmission? or does anyone have these parts? thanks!
