I might use a Tecumseh on a kart and would need to run a fuel pump. With a Tillotson do you still need the pump. Also, will a diaphram type lauson carb pump fuel?
If the Tillotson's pump fuel as-well what would be a good choice for a stock HS50?
If I go the fuel pump route what is a inexpensive rebuildable pump? Nothing high performance really. I just need to pump the fuel about 3" and up about a foot.
Thank You.
Thank You.
