Little Update: I got it running today!!! :laugh:
After reading several threads and other sites with small engine info, my Dad and I decided to try again. I had a specific plan of steps to follow this time. Also
big disclaimer: I decided to do all these things without engine oil in it since it was still "wet" inside the case and I have seen so many yt vids of ppl trying to burn up an engine that I wasn't afraid to run it without oil at idle speeds...
When I first started troubleshooting today, the engine was in this state:
- side cover off
- sparkplug removed
- cam removed
- rockers, pushrods, and lifters removed
- airbox off
- flywheel off
- flywheel nut on shaft (use for drill starting)
- no rope start
1) First thing I did was to get a feel for how much total endplay there was in the crank. It felt like a good 2 to 3mm of endplay. Next, I wanted to see what the "baseline" resistance to turning the engine over with the drill felt like. I did this for three different locations of crank endplay: flywheel nut farthest out from block, centered in between, and then flywheel nut closest to block. I found that the least resistance to drill rotating the crank was with it centered.
2) Now I installed the side cover, but before doing so, I cut up several strips of cardboard to use as a simulation gasket. I did not want to buy these gaskets ahead of time, in case it turned out to be the bearings got damaged somehow so I wouldn't have to order things twice. However, my Dad's mechanic friends took too long to take a look it, so I decided to give this a go ahead. Also, it didn't fully occur to me how the gasket thickness will determine endplay in the crank until I realized that the cam gear on the crank butts up against the bearing in the side cover.... For some reason, I kept thinking that there was a lot more space between them. Anyway, after installing the side cover with the faux gasket, I checked endplay feel and felt it to be about 10-30 thousandths of inch ; thus I was on the right track. The drill easily turned the engine over.
3) Now I was ready to install the rocker arms again. Removed the side cover, placed the lifters in then the cam in dot to dot. Reinstalled the side cover w/ faux gasket. Now I installed pushrods and the rocker arms and set the valve lash correctly. The drill turned the engine over easily, but with slightly more resistance than in step 2.
4) Now it was time to install the spark plug: the almost true test. Before doing so, I poured a tiny amount of engine oil inside the hole and cycled the engine several times. With the plug installed, there was no change in cranking resistance when the drill was applied.
5) Flywheel and airbox were installed, then it was showtime!!!
6) Gas lever ON, throttle lever to idle, Choke full: spin spin spin spin spin
spin spin spin spin.......... spin spin spin hiccup; hiccup... spin spin hiccup
hiccup hiccup,
BOOOOOOOM HUGE backfire that scared the crap outta my Dad hehehe
few more hiccups then it fired up!!!! The 3/4 inch socket came off the flywheel nut more easily than i expected!
I only let it idle bc there was no oil... Pulled the pplug wire... this could have been a fluke :blink:
7) tried to start again... spin spin hiccup hiccup, then vroom!! idling...
We both learned a lot through this process and I am ready to order some side cover gaskets and a new pull starter.
In terms of the billet rod and flywheel, how do I know which rod is the correct one?
there are so many different choices that are slightly different in size it seems. I have the 6.5 hp 196cc GX200 clone that came OEM with the Baja Warrior:
200cc 6.5 Hp Mini Bike Engine for the Baja Mini Bike MB200 (Baja Heat, Mini Baja, Baja Warrior) [Compatible With: Baja Motorsports] : Monster Scooter Parts
