Hi, I'm currently in the process of building my 212cc hemi head and have run into an issue. I applied assembly lube to all the internal gears and went to spin the crank by hand and it binds up after a few spins and will do it in both directions. It only does it with the front cover and camshaft in place. If I don't put the cam in then there is no issue with turning over. It almost seems as if something is pushing the camshaft out of the engine because it puts pressure on the front cover. I'm really at a loss to what it could be and haven't been able to find any info online. Also, I haven't even mounted the head yet so it isn't a compression or valve lash issue. Relevant mods are billet flywheel, billet 3.308" rod, and Mod2 cam. Thanks!
