Im in orlando an I was wondering how do I get a hemi predetor engine besides the regular one what is the difference between the two is it just the head how can I get one of those specific engines anyone got item ir part number .....:shrug:
i had typed out a response earlier and it didnt go thru, computer died, but looks like you got an answer... 60363, you cannot spec order by part number on the net
you have to go inside the store (outside CA) and look at the boxes... if not in the main part of the store, ask to look in the back... if you go into one and they do not have them... ask for the manager by name... tell him what you are looking for... ask when they receive new shipments in... reason being is that you can call back on a later date and ask for that manager by name. then ask him to look at the motors and for that part number, before driving back..
managers normally have more motivation as far as customer service and are less likely to get an attitude or not really look when you ask them to physically check the numbers.. if you dont, they may look in the computer, which will not tell them anything.. all the numbers are cross referenced to each other...
further on the difference, is the crankshaft, type of cam used and flat top, lightweight piston...
the cam it takes is the gx200 style... it takes a difference billet flywheel and the flat top piston is nice and much lighter than the regular... the intake valve in the head is already 27mm, which is nice...
