Found this engine and want know how to tell what it’s supposed to be. Extended shaft, lighted, slant intake etc. Is there a way to look that up. HS40- 55410C. Serial 1118B
Thanks, Eric
Thanks, Eric
Thanks, Eric
Ok. Thanks again. Could I bug you for one more. This one should correct for my 1970 Roadster. It has the 356 carb, extended crank with bearing, lighting coil, dip stick.
HS40-55282B. Serial 0280 08215
