I've been working on getting my HS40 up and running for some time now. For a week, I messed with the points system and finally got everything all tuned up. I put it on the motor, and it had good spark. I could hear the motor wanting to fire (the chug).
However, through some poor decision making involving me starting it with a power drill, I sheared the flywheel key and the flywheel came off (long story) and knocked the magneto/stator out of alignment. I was unable to get it to spark correctly after that. Finally I said :censure: it, and ordered a Nova II Electronic ignition system.
I installed it this morning. Once again, I have a really good spark. I haven't hooked it up to my ohm meter yet, but I'm certain it's ample.
No matter what I do the motor just won't start. :2guns::2guns::2guns::2guns: :censure: you engine!
It's getting gas. I've pulled the plug and it's wet. I've cupped the intake and it's getting air (I could feel it pulling. I checked the adjustments on the carb and everything is set up correctly. I have the valve cover tightened down, so it's not leaking. The compression is spot-on.
WTF else could it be!? I'm about 3-4 more attempts away from this thing becoming the next target at the local gun range.
