M Mikey Likes It Member Mar 6, 2014 #1 Mar 6, 2014 #1 What's the difference between a HS40 point engine and a electronic ignition engine? Can you interchange parts? Thanks-Mike
ZR9B Mar 8, 2014 #2 Mar 8, 2014 #2 I think the points are on the inside of flywheel and electronic are on the outside of flywheel...
oldfatguy Active Member Mar 8, 2014 #3 Mar 8, 2014 #3 The flywheels are different, the older point style engines had an aluminum fly wheel while the newer electronic engines had cast iron fly wheels .
