hs40 rupp crank drawing
I thought I saw on here some time ago a tec crank drawing showing the specs/location of a Rupp hs40 crank.
I have 2 cranks to be machined . Anyone have a copy of that drawing? If so could you e mail it to
kris1164@aol.com
Thanks in advance
Joe51
cranks I will be using
#1 is 1/16 " short of an original Rupp crank. This will be used in an HS50
#2 is 1/2" too long and will be cut shorter when it gets machined down. Will be used in an HS40.
Both length measurements are measured from the face of the crank gear to the end of the PTO end
compared to a NOS Rupp crank I have had since around 2012.
