HSSK50 small block mods
delray
been sitting on this motor for a while now and had little down time to start on this build for a future project bike or two? not sure which one i'm going to put it on first....:scooter:. both bikes came with lights and this engine has the lighted coil on it.
this engine was purchase with a bunch of parts also so it came out to be only $5 for it.
it appears from looking at the muffler it may have low hours on it?
the bore was nice and straight. so it will just get a quick hone and new rings.
here is the ugly part why no one wants these motors. crankshaft is crazy long with a 1inch shaft and a step down at the end.
delray
pull out one of my newer NOS bearing side covers and compared it with a older vintage rupp bearing cover. there are a few different things about them but for the most part they will still work for my project.
yep i think i might of just given it away what i am going to do...:cool:
mustangfrank
Have to remember that "Gold Series" label in the Spring when everyone is dumping snowblowers again cheap, can't always see an alternator connector in crappy CL pictures.
delray
starting from the left: standard length bearing crank,hssk50 bushing crank,rupp bearing crank,ohh bushing crankshaft(same length rupp's)this can be also change into a bearing crank with just a grove machine into it for the snap ring. yes the ohh user's a 1inch bearing I.D
delray
they are a dime a dozen in my state.;) also have found some 90's sears engines that come with a lighted coil,but no light on them. the snowblowers where that dark green with gold letters(craftsman). so double check them too.
delray
ok here is where the mod's start to begin. off to the lathe with the HSSK50 crank.
lot of material to take off.
still more to take off
after getting the first part of the area in spec's(.7864-.7860) where the bearing going to ride on. i went ahead and cut a grove for the snap ring.
next step i had to machine the area for the seal to ride on and that area run's just little smaller dem's .781-.779 and then cut down the rest of the area to .750 i actually cut this area to .7492 when test fitting a clutch or even a torque converter it seem to slide on nice and snug. i also notes when measuring couple other cranks this area was at .7490
here is how much extra material i cut off the end of the crank. .435 material
drilled and tap the threads little deeper and yes i am making it a rupp style crank with just under 3inch's long.
before taking the crank off the lathe i polish the new area with some emery cloth. so everything was kept on the high side knowing the emery could easily take off .001 material in time.
delray
Pretty slick, slick...thanks for sharing, you've given me more motivation to make space for a lathe and educate myself.
yes a lathe is nice to have and they really don't set you back when it comes to purchasing one. only thing i can't do is bore my own blocks,but that might change soon with few more tool items/fixtures for my mill.
mustangfrank if you like seeing what i did with a hssk50 crank. your going to want to get a lathe for sure when you see what i'm going to do next. another one off first that i believe no one has done yet.....:scooter:
mustangfrank
Right on, I'll probably never do anything too advanced just gets old having to make runs to a machine shop for little projects.
delray
this morning i grabbed couple comet units and test fitted them to the crank and they fit like a grove. very happy with way they fit. nice and snug on the crank and keyway. now i'm just waiting for the new bearing to come and see how that fits. keeping the bearing surface on the high side. so if it's to tight i can easily bring that measurement down.
delray
here is something else to see when the torque converter is fully installed on a rupp style crank. it almost comes to the end. making the driver much more stable on the crankshaft then it would be with a stock standard length crank.
delray
bearing came and it was spot on for fitting. glad i kept my measurements on the high side. less chance of having the inner race spinning on the crank.
snap ring also was right on too with no end play.
looking good,real happy how everything turn out.
bearing number i use was a 6204-2rs. just pulled the seals off and good to go.
delray
I like this build, I have a newer style Tecumseh 5hp build too but it is not set up with a roller crank. Are you going to put a roller bearing on the other side?
rob, i am not on this one. going on one of my vintage bikes that came with lights. i need the lighted coil and this engine is a cast steel flywheel so going to keep it under 5000rpms....lol
maybe on the next build....;)
delray
If you start retapering Billet Briggs flywheels to fit these HS50s I want one :)
need to start looking into a billet flywheel one of these days. just when i think i have little time to work on some of this stuff now i got some friends calling and want me too go flat track ice racing.......:scooter: so this build may slow down just little.
