Anyone have ideas on how to shut off a Snow King engine that doesn't have a kill switch wire (green)? I have one mounted on my MTD/Columbia Mini Cycle (model 653-2) and the key was removed by Small Engine Warehouse for a minibike/kart throttle set up.....Help!
OK if you wanna run a kill switch. Just remove the side cover, and on the coil should be a male terminal. Run a wire from that to a kill switch, and from the other side of the switch to a ground. :thumbsup:
Tecumseh also used a clip mounted on the cylinder head that you shorted the plug out with. You should be able to find one from a mower shop or something.
Or you can do what the junior dragsters do, put a zip tie around the end of the plug wire, and leave the end nice and long.:wink:that way you can yank on the zip tie and not have any chance of getting shocked.
